moonwatcher64
Aug 29, 2022Luminary
Newbie Meural Q - How to Access Pics on SD
Hi all, after a slightly wobbly start wiring in my M-II, we are up and running & impressed with it. But having just downloaded a load of photos (as a test) to a 512GB microSD and inserted into th...
- Nov 14, 2022
Hello moonwatcher64,
Thank you for your post!
Please format your SD card to FAT32. There are instances that Win10 will format drives to the NTFS format as default. NTFS is a newer drive format than the FAT32. However, it will not work with your Meural Canvas.
Best,
Kevin
Community Team
moonwatcher64
Nov 12, 2022Luminary
Forgot to add that I did add folder as meural1 as well.
Thanks
KevinLiT
Nov 14, 2022NETGEAR Moderator
Best,
Kevin
Community Team
