0G
Jan 10, 2023Tutor
Page that lists Meural canvases firmware versions and changes in firmware?
Can someone please send me a pointer to a list of Canvases firmware history and the firmwares contents/updates? I'm unable to find what the latest available firmware are (and then I'd like to know wh...
KevinLiT
Jan 10, 2023NETGEAR Moderator
Hello 0G,
Welcome to the NETGEAR Community!
I understand that you would like to ensure that you are on the current firmware version of your Meural Canvas. There is no need to manually download firmware for this device.
Please do the following to ensure your Meural Canvas is on the most current firmware:
- Open the Meural App
- Tap "CANVAS"
- Then tap the "Settings" icon at the top
- Next tap "Canvas Settings"
- Scroll all the way to the bottom of that page and select Software Update
If the Canvas needs to be updated it will prompt you with an update option. If it does not that means your Meural Canvas is on the current firmware.
Best,
Kevin
Community Team
0G
Jan 16, 2023Tutor
Hello KevinLiT ,
No, I'd like a list/history of firmwares for the canvases: version, release date, fixes/features brought by the firmware, release notes, etc... Basically what I see for Netgear routers for instance (e.g. R6700AX | WiFi 6 Router | NETGEAR Support).
Best regards,
Olivier.
