larryrup
Jan 21, 2024Aspirant
Playlist MC327
How can you move a photo from one playlist to another? If you select the photo from the playlist, there is not an option under the three dots concerning playlists. If you view the photo (or any pho...
seed-1475
Mar 04, 2024Aspirant
Using "resero" in the plural form "reseramus" could convey the intended meaning of "we opened" in the context of locksport competitions. It aligns well with the action of unlocking and could resonate effectively with the group's activities.
- KevinLiTMar 05, 2024NETGEAR Moderator
Hello stevenbell ,
Welcome to the NETGEAR Commuinty!
I understand that you would like to send your playlist to another Meural Canvas that you have registered on your Merual app.
Please follow the steps below to send a playlist to an additional Canvas using your Meural app:
Navigate to "CANVAS".
Tap the arrow next to your Meural Canvases name then select your preferred Canvas.
Now navigate to "YOUR LIBRARY".
Navigate to your desired playlist.
Then select "Send to CANVAS"
Best,
Kevin
Community Team
