Starfishj
Jan 15, 2026Follower
Possible to use both cloud and SD storage?
Hi,
like many others, I have run out of space in my cloud storage on my Meural II. I like the cloud interface - it’s super buggy, but I like that I can just select photos from my phone and send them to the Meural instantly vs download. However, I need more space.
I know that there is an SD card option. Is there a way to use both the cloud and the SD card? Or do I have to use one or the other?
I currently use the scheduler option to have different playlists show at different times of day (ie. “travel” plays from 2pm - 4pm on Friday but from 10am-noon on Saturday - i do this with 5 playlists and rotate them so I see different photos all the time).
I have 2 questions :
- is there a way to integrate the SD card and the cloud so that I can see photos from playlists on both? Or do I have to go all in on SD card to really make it work?
- Can i have rotating playlists from the SD card? Or do they just play in order - playlist1 (image 1 - 100 in order), then playlist2 (image 1 - 100 in order) and so on?
the SD card is just way less convenient for taking a photo and adding it same day. I’d love to keep that functionality for at least some of my photos if possible
many thanks
1 Reply
- jamy46435Aspirant
You can use both cloud and SD card on your Meural II, but they don’t fully integrate. Cloud playlists let you quickly add photos from your phone, while SD card playlists are stored locally and separate. You cannot mix images from both in a single playlist. However, you can schedule SD card playlists just like cloud ones, and within each playlist, images play in order or can be shuffled for variety. A good approach is to keep the cloud for instant uploads and use the SD card for larger libraries or randomized playlists.
