sathyanveshi's avatar
sathyanveshi
Follower
Jan 01, 2024
Power adapter voltage compatibility (Meural Canvas II) MC327
Hi there
I bought a Meural Canvas II (MC327) in Canada and now I have moved to India. I am yet to hang the Meural as I am concerned about the voltage compatibility of the power adapter. In Canada the voltage is 110v but in India it's 220-240V. Wondering if the supplied adapter in Canada would be compatible in India? Thanks.
Cheers
Mohan
1 Reply
  • plemans's avatar
    it doesn't show if it'll work with 220v on that adapter. You could always use a power adapter or pickup up a third party power supply. As long as the output voltage and polarity are the same, it should work
