Vic_G
Nov 26, 2019Apprentice
Meural Canvas II: Bug? Removal of SD card w/ playlists does not completely remove references
Hello, please let me know if I should be posting this elsewhere ..... Issue 1 involving SD card based playlists On SD card created 4 playlists: meural1, meural2, meural3 and meural4 with a few ...
HolgerScheller
Feb 01, 2020Aspirant
Hey guys,
have a Canvas II since Friday and I'm struggling with the SD card handling too. Did you try ever to use subfolders in the meuralx folders? Does not work for me :-(
You also mention that the SD card content is shown as a playlist!? I have to open the menu and the option search to see those folders.
Thanks and greetings from Heidelberg, Germany
Holger
Vic_G
Feb 01, 2020Apprentice
Hello Holger!
I've never gotten subfolders to work. I doubt that they do. My guess is that the Canvas will only recognize files within the folders meural1 through meural4. Folders within the meuralx folders probable will not be recognized.
As for having your meural1 through meural4 folders appear as playlists, the only thought that comes to mind is that once you insert the SD card into the Canvas, completely unplug the Canvas from the power outlet and wait 10 to 20 seconds (go for 20) before plugging the Canvas back into the power outlet. Do not depend on the power button on the side of the Canvas to do this. I needed to literally pull the plug.
When I followed that process, the meuralx folders on the SD card started showing up as playlists.
Hopefully these ideas will help a little bit.
And greetings to you from Kentucky in the United States!
Vic
