FabledFanatic
Nov 21, 2020Aspirant
Replacement Anchor size for mount? Anybody know?
I am notoriously bad at installing anything level the first time. I have no idea why I thought the Meural would be any different... anyway, suffice it to say, I now have two gigantic holes in my wall...
FabledFanatic
Nov 22, 2020Aspirant
Thank you plemans! Do you remember what size/type you used? Home improvement stuff is 3000% not my wheelhouse, so I have no idea what I'm looking for... (I think Molly anchors were the ones packaged here? Definitely open to alternatives though, so long as they work!)
Nov 23, 2020Guru - Experienced User
I don't think I had to buy them. I have a small collection of them from installtion other projects and think I found one in the collection. Sorry!
But I do remember i had to sand/grind the head of the screw a little to make it sit flush in the mount.
