Vic_G
Dec 20, 2019Apprentice
Sample Playlist Removal
Hi, What is the process for removing the sample playlists from my Canvas II? I have set the Canvas II attributes to rotate through the playlists on the Canvas II. This results in all of the ...
- Dec 23, 2019
Hello Vic,
Thank you for the question.
To delete a playlist, go on my.meural.com and click on the User icon in the top right hand corner of the screen, it looks like a person in a circle. Next, click on Canvases in the drop down menu. On the next screen click on playlists at the top right hand corner. On the following page you will see all of your playlists. Click on the three horizontal dots in the lower left hand corner of the playlist and then click on Remove from Canvas to remove the playlist from your Canvas.
You can also click on 'Works' to manual any individual pictures you'd like to edit or remove.
Kevin K., NETGEAR Meural Community Team
KevinJ_K
Dec 23, 2019NETGEAR Employee Retired
Hello Vic,
