scmarti
Feb 03, 2022Tutor
Scheduled "Wake" is not working
Purchased canvas a year ago, configured the schedule, and had no issues with the Wake function. Recently upgraded the canvas’s software ver.to 2.2.10_2.0.13 AND deleted the schedule (wanted some...
KevinLiT
Feb 16, 2022NETGEAR Moderator
Hello scmarti,
Thank you for bringing this issue to our attention. I informed my team of the Auto-Adjust Feature issue with the Meural Canvas. We are working diligently to solve this issue.
Best,
Kevin
Community Team
JWS9518
Mar 26, 2022Luminary
Having same issue here. I turned off the auto settings, but still powering off and not automatically coming back on.
When will this bug be fixed?
- srbrouwer2Jun 09, 2022Aspirant
I am also having the same issues as described above. The scheduler used to work just fine. Sometime in January 2022 it stopped waking and/or sleeping automatically according to the schedule. I have tried all of the recommended suggestions on all of the various messages regarding this issue and I cannot find a solution that works for me.
Can you please let me know when this issue will be resolved and if there is a new update coming? Can you also please tell me the current version of the app and canvas software.
- KevinLiTJun 09, 2022NETGEAR Moderator
Hello srbrouwer2,
I am sorry to hear that you are having issues with your scheduler. Adjusting the light sensor sensitivity can help resolve this issue.
The current app version is: V5.2.8
Below are instructions on how to adjust the light sensor sensitivity on your Meural Canvas:
To adjust the light sensor from my.meural.com:
- Login to my.meural.com.
- Go to Canvases.
- In the upper left-hand corner, select the canvas you want to adjust.
- Scroll down to Light Sensitivity.
- Adjust the light sensitivity to Low, Normal, or High.
Best,
Kevin
Community Team
- joer1974Jun 20, 2022Aspirant
Kevin, You missed part of the question"please tell me the current version of the app and canvas software." You gave the "current app version" but not the current version of the canvas software. I have been searching the Meural site for quite some time and cannot find anywhere that this information is listed. To be clear this is the version of the software that is running on the canvas NOT the app that is running on the mobile phone. I currently have the version 2.2.10_2.0.13. If this version is the "latest" it means that it has been around for OVER 1 YEAR. This means that there have been NO FIXES to the software for OVER 1 YEAR.
