HJV
Dec 19, 2020Aspirant
SD card not detected on Meural Canvas II
Hi, I recently purchased a Meural Canvas II. I am unable to use an SD card on my device - it is not detected when I put it in. I have followed all the suggestions mentioned on your website but am una...
gorillashots
Mar 18, 2021Tutor
They sent me a replacement Frame, this one is fine and can see the SD Card,
but here is the CATCH!
they don't thell you that SD Card can be seen only from the frame it's self not from the App nor web browser, it's a lame crappy design with hefty price. So here is what you need to do to see the SD Card. Basikley I am writing SOP for Nergear/Meural for free sinse their engineers are so busy with other bull **bleep**.
1. Make sure you have good quality SD Card (Class 10 UHS) I am using Lexar
2. Create 1 to 4 folders and called them as - meural1 meural2 meural3 meural4
3. Paste your "mpg" pictures in thoes folders (I have about 100 pictures in each folder)
4. Insert the SD Card and Unplug the power of your Frame
5. Plug the power back in and let it boot up completley
6. Use you hand gestures front of frame and go to "Playlits"
7. Then try to wave Up or Down till you see the SD Card
DON"T use the APP or Web Browser
Muda
May 20, 2021Aspirant
Thanks GS.
Yea, Netgear, build an app that can't see the SD card and play the playlist.
Really? Built by the "C" team?
Shame, as it's a really nice product.
Oh well, it works now.
