HJV
Dec 19, 2020Aspirant
SD card not detected on Meural Canvas II
Hi, I recently purchased a Meural Canvas II. I am unable to use an SD card on my device - it is not detected when I put it in. I have followed all the suggestions mentioned on your website but am una...
haguin93
Jun 09, 2021Aspirant
But I have no issues with meural convas I am using it from last threee months and I used SD card it it several times and the output was very nice tell me the complete detail may be I canhelp you in any way to solve this issue.
meuraldon
Aug 22, 2021Aspirant
My Meural Canvas II was able to see my SD card. It worked for a few months. Now it no longer detects the card. I've called Support three times on this and never receivedd the promised callback.
- mattwillhillAug 22, 2021GuideIn my experience the Meural never sees the SD Card if its reinserted while WITH POWER.
Have you tried a complete reboot, meaning completely removing mains power?
i.e.
Remove the SD Card. Power down by removing the plug (don’t just switch off at the monitor). Leave for 3 mins.
Now reinsert the SD card while powered down ensuring its fully re-engaged.
Now power up by plugging in at the mains.
Wait 2 mins before scrolling the menu for files?
If the unit still fails to read this SD Card, try a new one for comparison as a test. Again completely power down at the mains, insert while powered off and power up with card in situ. Remember that the file folders must be labelled correctly.- meuraldonAug 22, 2021Aspirant
Thanks for taking the time to post.
I actually have 2 SD cards; neither work. The formatting is correct and, in fact, both worked at one point. Now neither works. I've done a full reset, taken the power cord out.....
No luck.
Supposedly a "high level technical person" is going to call me tomorrow to try to problem solve.
Thanks again.
