HJV
Dec 19, 2020Aspirant
SD card not detected on Meural Canvas II
Hi, I recently purchased a Meural Canvas II. I am unable to use an SD card on my device - it is not detected when I put it in. I have followed all the suggestions mentioned on your website but am una...
mattwillhill
Aug 28, 2021Guide
My meural has only the SD Card slot on the bottom side - it makes no sense for there to one on the back. I did experience a problem with old SD cards & reformatting so I bought a new one which worked fine. The Meural only recognises SD cards and card updates if the unit is completely powered down and switched off at the mains supply.
