newframequestio
Dec 23, 2019Follower
SD Card Not working
I am putting the frame in a part of our house that has very bad wifi. So I set up the frame in an area with good wifi this morning and then I bought an SD card with 128 GB of storage. I follo...
Urolupo
Sep 19, 2020Aspirant
Hi! Did you finally get your 128gb sd card to work efficiently on your canvas?
- MeuralmeOct 17, 2020Aspirant
I am having the same issue. I first used an 128GB and then i read that i should use up to 64 only, so i used a 4GB card and i followed all instructions (file extension, naming convention, created folder "Meural1", insterted it on canvas, unplugged and on again), but nothing shows up.
Please help!
- MeuralmeOct 22, 2020Aspirant
Ok, i fixed my problem. All the photos I had saved on the card were landscape, so when the Meural was hung on portrait, the SD card wasnt detected. I rotated the Meural to landscape and, boom, there was my card and all my photos. Just sharing for someone that might find this useful.
