jettenj
Mar 17, 2024Aspirant
SD card thumbnails
When I add photos from my Iphone I do see manageable thumbnails in the Meural app. When I insert a SD card with JPG's they are displayed wel. However, when e.g. starting a SD card based playlist I d...
KevinLiT
Mar 18, 2024NETGEAR Moderator
Hello jettenj ,
Welcome to the NETGEAR Community!
I understand that you would information on how to use an SD card with your Meural Canvas. The SD card must be formatted in a way that is compatible with your Meural Canvas. The works added to your SD card must also follow specific formatting guidelines. Listed below are the recommended compatible format configurations to get you started with successfully storing and displaying the works on your Meural Canvas.
Thumbnails must be 120 pixels x 68 pixels for horizontal images and 68 pixels x 120 pixels for vertical. Thumbnail names must be formatted as the following:
- [filename].[filetype].thumb
To use your SD card as a storage option it needs to be formatted in one of the following formats:
- FAT32.
- exFAT.
- ext4.
- In addition, the memory cards can have a maximum capacity of 512 GB and must be formatted.
On your SD card you can create up to four folders, each folder is considered a playlist. The folders on your SD card must be named the following (The folder names are case-sensitive):
- meural1
- meural2
- meural3
- meural4
The photos that are stored on your SD card must be formatted as one of the compatible formats listed below:
- .svg
- .avi
- .mkv
- .mp4
- .mov
- .heic
For additional information on the recommended format for your SD card please visit the link below:
How do I add images or videos to a memory card for my Meural? - NETGEAR Support
Best,
Kevin
Community Team
jettenj
Mar 19, 2024Aspirant
Dear Kevin,
Thank you for this detailed answer. However, it does not answer my question.
I want to see thumbnails with a small image of the photos on my SD card to allow me to move to a certain picture.
The present thumbnails are all blank. The same is true for the iphone app.
- KevinLiTMar 20, 2024NETGEAR Moderator
Hello jettenj ,
Thanks for the additional information in regards to the reported issue!
Please try the following to troubleshoot this issue:
- Please ensure that your Meural app is updated by removing the app then reinstall it from your app store.
- Then, Ensure your Meural Canvas is on the most recent firmware by navigating to settings>CANVAS DETAILS>Software Update.
- If the issues is still present, please try removing your SD card then perform a factory reset on your Meural Canvas.
- After completing the factory reset insert your SD card into your Meural Canvas then power it on.
Best,
Kevin
Community Team
- jettenjMar 22, 2024Aspirant
Ok, I will try that although it seems unlikely that a new canvas with up to date software would need a factory reset.
Besides is it possible to show me a sample of a screen where the thumbnails from a SD card a visible?
- Mat_tiaJul 30, 2024Aspirant
Hi there,
In my case, I had to create a separate file for the thumbnails to visualize them.
Then they will be visualized in the menu when you move across images.
Hope it helps!
