LJ701's avatar
LJ701
SD Card upload
Hi, Can I actually upload the pics from an sd card to my Meural Canvas II?  I do not want to leave the SD card in the monitor.  I do not see anywhere that it allows me to actually upload.  The Meural does find the pictures, but I'm not sure what happens if I remove the SD card.  Thank you for your help.  LJ
  • Hello LJ701,
    Welcome to the NETGEAR Community!!
    I understand that you would like to load the pictures from your SD card to your Meural Canvas II.
    To add pictures to your Meural Canvas II using an SD card you will need to insert the SD card into a computer and then follow the  instructions below:
    1. Launch a web browser and visit my.meural.com.
    2. Click LOG IN at the top right.
    3. Enter your NETGEAR account credentials and click LOG IN.
    4. Click the + icon at the top right.
    5. Locate and select the pictures or videos to upload.
    6. Click the account icon at the top right.
    7. Select Uploads from the drop-down menu.
    Your recently uploaded files display at the top.
    Best,
    Kevin
    Community Team
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello LJ701,
    Best,
    Kevin
    Community Team
    • LJ701's avatar
      LJ701
      Kevin, thank you for your reply.  Have a great day.
    • LJ701's avatar
      LJ701
      Thank you for taking the time to answer. Have a great week.
