fickas's avatar
fickas
Set constant brightness on Meural canvas
I can set the brightness for individual pictures. But I would like to set the same brightness for all pictures. And I would like this level to remain the same each day. Is there a way to set a brightness level as a constant for all pictures shown? And not have to redo it each day and for each picture?
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello fickas,
    Welcome to the NETGEAR Community!
    I understand that you would like to set a constant brightness on your Merual Canvas for your displayed works. This can be done by modifying the auto brightness feature through your Meural app.
    Follow the steps below to adjust the auto brightness for your Meural Canvas through your Meural app:
    1. Tap CANVAS.
    2. then the gear icon on the top right of the screen.
    3. Now tap Canvas Settings.
    4. Scroll down to Light Sensor.
    5. toggle off Auto-Adjust Brightness.
    6. then, tap Light Sensitivity.
    7. Now tap low then adjust the light settings on your Meural Canvas.
    Best,
    Kevin
    Community Team
    • EM1-X's avatar
      EM1-X
      Hi Kevin,
      I followed your instructions above and came to #7. I tapped low but now I'm not sure where I can adjust the settings. There is nothing in the app for this procedure.
      Thanks.
      • KevinLiT's avatar
        KevinLiT
        NETGEAR Moderator
        Hello EM1-X ,
        Thank you for your response!
        Sorry for the confusion. Next to the "Light Sensitivity" location look to the right. By default, you will see "medium" and a ">" sign. Tap that it will take you to another page that will give you three light sensitivity options: "Low", "Medium", and "High". On that page, you will tap the "Low" option.
        Best,
        Kevin
        Community Team
