Castletyphoon
May 22, 2023Tutor
Shuffle Images
Hi all
I have a few folders which of photos which I have taken. Meural shuffles within these folders but can it shuffle all photos in all folders?
Thanks
- danielcarterAspirant
Meural currently shuffles photos within individual folders, but it doesn’t support shuffling across all folders at once natively. Workaround: You can create a playlist or a single folder that includes photos from all your folders, then enable shuffle on that. This way, Meural can shuffle across your entire photo collection. Hope that helps!
- KevinLiTNETGEAR Moderator
Hello Castletyphoon ,
Welcome to the NETGEAR Community!
I understand that you would like to shuffle the order of the photos displayed from all folders. This can be achieved by adding the photos to a designated playlist and then configuring the Image Shuffle setting on your Meural App. When this option is turned on, the images from an individual playlist will be randomized.
Please follow the steps below to change your Image Shuffle configuration:
Open your Meural app > Tap canvas> Then canvas settings> scroll down > then toggle Image Shuffle on.
Best,
Kevin
Community Team
Hi Kevin
Thanks for helping with this.
The SD card doesnt show up as a playlist on the app which is where the images are.
Thanks
Stephen
Thank you for that additional information!
Folders must be used when using an external SD card for the Meural Canvas to be able to view the images within as a playlist. When using folders the folders must be named meural1, meural2, meural3, and meural4. The folder names are case-sensitive.
Please visit the link below for additional formatting information:
How do I add images or videos to a memory card for my Meural? | Answer | NETGEAR Support
Best,
Kevin
Community Team
