Mr_Oizo
Nov 27, 2020Aspirant
Slideshow with Meural WiFi Photo Frame
Hello dear Community, I did not found an answer to my question on the available FAQ. Is it possible to create, on this photo frame, a slideshow of selected photos by defining a display duration...
Mr_Oizo
Thank you for the answer.
In fact my need is much more basic. It is about automatically scrolling through the photos with an interval of a few seconds, instead of having a photo frozen in the frame.
Nov 27, 2020Guru - Experienced User
You can set the image duration from 1 second on up. I just changed it on mine and it worked fine
- Mr_OizoNov 27, 2020Aspirant
Many thanks !
So I need to upload my pics, do a playlist, choose an image duration and it works ? I will have a slideshow with all my pics on the Meural WiFi Photo Frame (which has quite the same feature of Canvas II) ?
- plemansNov 28, 2020Guru - Experienced User
Mr_Oizo wrote:Many thanks !
It did for me. I was going to use it for art but the bigger ones would be better for that. for family pictures, its great.
