omero
Jul 31, 2020Follower
Switch FSM750S factory reset
I got an old Netgear Switch FSM750S but I forgor its password. I have tried already the admin: " ", admin: 1234, admin: password, and so on without any luck. I haven’t found a way in on the manuals either.
Please help if you know.
Regards
This is the data when booting
RDU Product coming up...
CPU type is RC32332 revision 0x00
DRAM found is 16MB
Testing DRAM...OK
DRAM found is 16MB
Testing DRAM...OK
Booting up... Ver 1.1 (2274) (20020711)
Reading non-volatile data...
Boot from flash...
Reading image from flash... Done.
Decompressing image... Done.
Expanded to 3999744 bytes, CRC 29fe302f
Loading image... Release 2.6.5 (6035) (01201053)
Code Size............................9404K
Total Free Memory Size...............6980K
Start Address..................0x8092f000
End Address..................0x81000000
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
Copyright 1989, 1991, 1992 by Carnegie Mellon University
Derivative Work - 1996, 1998-2000
Copyright 1996, 1998-2000 The Regents of the University of California
Copyright (c) 2001-2003, Network Associates Technology, Inc
Portions of this code are copyright (c) 2001-2003, Cambridge Broadband Ltd.
Copyright (c) 2003 Sun Microsystems, Inc., 4150 Network Circle, Santa Clara,
California 95054, U.S.A. All rights reserved.
Initializing...
System Interface Attachments:
Device tty0 has been attached.
Device de0 has been attached.
Device nd0 has been attached.
System Initialization Completed....
Copyright(C) 1998-2002 NETGEAR(TM)
login:
No RepliesBe the first to reply
