Zarou
May 09, 2024Tutor
Turn off auto on
Is there a way to have the Meural NOT turn on when it senses light. I currently have it on a schedule where it goes on at 9 AM and off at 6 PM but if someone turns on the light in the room the Meural ...
- May 10, 2024
Hello Zarou ,
Welcome to the NETGEAR Community!
I understand that you would like you Meural to stay off when it sense light. This can be adjusted in the light sensor settings on your Meural app.
Follow the steps below to adjust the auto brightness for your Meural Canvas through your Meural app:
- Tap CANVAS.
- then the gear icon on the top right of the screen.
- Now tap Canvas Settings.
- Scroll down to Light Sensor.
- toggle off Auto-Adjust Brightness.
- then, tap Light Sensitivity.
- Now tap low then adjust the light settings on your Meural Canvas.
Best,
Kevin
Community Team
KevinLiT
May 10, 2024NETGEAR Moderator
Hello Zarou ,
- Tap CANVAS.
Best,
Kevin
Community Team
Zarou
May 11, 2024Tutor
Thank you so much! I appreciate your kindness!
