Sidwin
May 02, 2020Aspirant
Upgrading from base mount to swivel mount on Meural canvas 1
If I upgrade from standard mount that came with the canvas to swivel mount, are the holes the same? Or do I have to drill new holes?
According to an Amazon review: https://www.amazon.com/gp/product/B07WC9MSW8/#customerReviews the holes seems to be different. I waited for swivel mount and put that one instead hence don't have the firsthand experience, but visually they seem to different in dimension (distance between the mounting holes)
1 Reply
