Explorer736
Jul 30, 2020Aspirant
Wall grommet solutions for Meural Canvas device
Good day Netgear Community, I recently purchased a Meural Canvas and would like to hide the cords behind my wall. The power cable for the canvas prevents me from using most wall grommets (cable ...
Jul 30, 2020Guru - Experienced User
Monoprice makes some pretty nice wall "media boxes" that have a power receptacle and space to tuck in the wires. I've used them before for media projects.
for instance: https://www.monoprice.com/product?p_id=18660
but there's many different ones depending on what you're trying to do.
Explorer736
Thank you for the response. If I were to choose this option, I'd have to find an extension cord/wiring that is code certified to go behind the wall.
- plemansJul 31, 2020Guru - Experienced Useri'm not an electrician but since it has a standard outlet, couldn't you wire it off an existing outlet and use in wall wire?
- Explorer736Aug 10, 2020Aspirant
I found a better option for anyone interested:
https://www.powerbridgesolution.com/product/two-ck-connector-kit
It fits well and can be purchased directly from Power Bridge Solutions or from 3rd party distributor/retailers (Best Buy, WalMart, etc.).
Hopefully in the future NetGear makes Meural power plugs without such a large housing!!
