LarryBraga
Feb 08, 2022Initiate
warning unresponsive script
Using a Mureal II with a 64KB SD card with 1000 pictures. Ocassionaly I get this message. Warning Undresponsive Script. A script on this page may be busy or it may have stopped responding, You...
Feb 09, 2022Guru - Experienced User
Maybe you mean a 64gb? 64kb wouldn't hold 1000 pictures unless they were pretty small/poor quality
Is it formated right?
What speed is the card?
Are all the photos in a proper format?
https://kb.netgear.com/000060777/Can-I-use-a-memory-card-with-my-Meural
https://kb.netgear.com/000064426/How-do-I-add-images-or-videos-to-a-memory-card-for-my-Meural
LarryBraga
Feb 09, 2022Initiate
Yes it is the correct format, the card is 64gb, card is speed (1)
The group of 1000 pictures were resized using microsoft power tool ..........resize
the largest is 674KB 1080x1620
strangley if i uses the original photos........not resized it runs
with pictures as large as 9357 kb in a 3468x5472 format........strange
- plemansFeb 09, 2022Guru - Experienced User
so it runs fine if they aren't resized?
I'd leave them as is then. Could be a reformating issue
