Gephotonyc
Aug 23, 2024Aspirant
Where do I manage cloud storage?
Can't update images on my Meural because it shows cloud storage is full. Deleted two galleries and it didn't delete them from cloud storage. Loved my Meural before Netgear bought them. Now I loa...
Gephotonyc
I didn't know the sd card would expand the onboard memory, but how to use it if the cloud storage capacity limits my ability to upload?
So I deleted two galleries on the meural, but the cloud storage still says it is full. In my uploads folder I only see about 50 images, and all ones I just added. I can't get to files I might have wanted to delete.
This is all quite infurating. Even if I do a factory reset my cloud storage would still be full wouldn't it?
This doesn't make any sense.
Garrett
Gephotonyc
Is there a way to just purge my cloud storage?
- GephotonycAug 23, 2024Aspirant
The uploads page is now showing more images, but I can't tell which ones I had been wanting to delete. Grrr
As I scroll down the uploads page I'm finding more images that don't have the on meural banner. Are those safe to delete?
