Klienstein1
Jan 02, 2022Follower
1 of 2 MS60 satellites connect
I received the MS60 mesh router and two satellites. One of the two satellites will disconnect when moved more than 6 feet away. All devices appear to have firmware versions V1.0.6.116.
Jan 02, 2022Guru - Experienced User
So placing it in the MS in the same location as the other MS sees same problem?
Might be a bad MS.
Netgear has set up a community forum specifically for the NightHawk MESH products. Most of the people who watch that forum are more likely to have experience with NH MESH products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Thank you.
