convolution
May 16, 2020Follower
192.168.1.1 didn’t send any data.
Just bought Nighthawl MK62. Operation and setup are fine. But using browsers to change the names and priority of devices failed. After pressing 'Apply', "192.168.1.1 didn’t send any data." is shown and nothing changed. This happened in Chrome. Tried Safari and no response. As the iOS app has function limitation, I need to use the browser to do some configuration.
Firmware is most updated. Don't know whatever should be done to fix it.
Convol.
1 Reply
- Christian_RNETGEAR Employee Retired
Hi Convol,
May you provide us with the current firmware version your system is on.
Thanks,
Christian
