kyle-io's avatar
kyle-io
Follower
Sep 18, 2020
2 Questions regarding backhaul and SFP media converter
Hi everyone I have a few questions regarding my Nighthawk Mesh MR63 AX1800.
The first is regarding using the backhaul feature. My home had network cables ran when it was built, I just haven't utilized them yet, and I'm noticed that infrequently the satellites will drop connection - which also occured on my old mesh system. I think this is probably due to it being a newer house, and the satellites being on different floors. I know you can backhaul these, my question is, do I need any kind of specific network switch to make this work, or will any do? Should I be looking out for anything when I purchase a switch?
My second question is regarding using an SFP Media Converter. I have Fibre internet, and I know on most actual routers, I would be able to buy an SFP Media Converter and get rid of the router provided by my ISP which would be great, as it's rather big and clunky. Would this work with the router on my Nighthawk Mesh system? I thought I read somewhere that some mesh systems may not work with something like this.
Thanks so much!
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hy kyle-io,
    Were you able to get a switch working with your mesh system? We have not received any feedback of the use of a SFp Media Converter with the Nighthawk Mesh system. However, we do recommend that a modem is paired with the Nighthawk Mesh system.
    Christian
