Ajai82
Dec 07, 2021Aspirant
200 mbps to 100mbps MR60 night hawk ax1600
I recently bought MR60 nighthawk Ax1600 with one satellitee, upgraded from TPlink archer C6 . My internet provider speed is 250 Mbps. my old router hit about 200 mbps in my mobile and laptop but now w...
Dec 08, 2021Guru - Experienced User
Are you testing over the 2.4ghz or the 5ghz?
2.4ghz is a much slower network than 5ghz.
And the MR systems do band steering so its not something you can just "choose" to be on the 5ghz.
Ajai82
Dec 08, 2021Aspirant
i tested with 5 ghz
- plemansDec 08, 2021Guru - Experienced User
what wired speed do you get from the router?
What speeds do you get over 2.4ghz?
What modem is it connected to?
Have you checked its internet connection statistics to see if its connecting at gigabit speeds?
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
- Ajai82Dec 08, 2021Aspirantwhat wired speed do you get from the router? 95Mbps
What speeds do you get over 2.4ghz? i dont have device to check
What modem is it connected to? direct from ISP (ACT) india 250 MBPS
Have you checked its internet connection statistics to see if its connecting at gigabit speeds? pic attached- plemansDec 08, 2021Guru - Experienced User
Your statistics are showing your only connecting at 10/100mbs speeds from gateway----router.
Try replacing the ethernet cable with a high quality cat 6 cable. I've seen sketchy cat 5E not connect at gigabit speeds.
- michaelkenwardSep 30, 2023Guru - Experienced User
Ajai82 wrote:
What modem is it connected to? direct from ISP (ACT) india 250 MBPSThat's the ISP and speed, it does not tell us what that modem is. Make and model?
