Ajai82
Dec 07, 2021Aspirant
200 mbps to 100mbps MR60 night hawk ax1600
I recently bought MR60 nighthawk Ax1600 with one satellitee, upgraded from TPlink archer C6 . My internet provider speed is 250 Mbps. my old router hit about 200 mbps in my mobile and laptop but now w...
Ajai82
Dec 08, 2021Aspirant
i tested with 5 ghz
Dec 08, 2021Guru - Experienced User
what wired speed do you get from the router?
What speeds do you get over 2.4ghz?
What modem is it connected to?
Have you checked its internet connection statistics to see if its connecting at gigabit speeds?
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
