mangoose
Feb 16, 2021Aspirant
400 Bad Request for IP address reservation on Nighthawk MR60
I am trying to get my security cameras on reserved IP addresses, but my MR60 router will not allow me to reserve. I have a MR60 router with 3 different MS60 satellites wired to distant parts of the h...
antinode
Feb 16, 2021Guru
> In Advanced>Setup>LAN Setup>Address Reservation, when I try to add, I
> get the following error:
> 400 Bad Request
"try to add" _what_, exactly?
Generally, a HTTP error 400 suggests defective firmware and/or
corrupt settings.
> [...] ALL running the most recent firmware, [...]
As always, an actual version number would be more useful than your
opinion of what's "most recent" today. Also, "most recent" and "best"
are spelled differently for a reason.
mangoose
add an IP address reservation
firmware: Firmware Version V1.0.6.110_2.0.49
- antinodeFeb 17, 2021Guru
Which part of "exactly" was unclear? Is it a _valid_ LAN IP address?
I can't see it from here.I still suspect a firmware defect. If you have some time to kill,
then you might try a settings reset and manual reconfiguration. Or
loading a different/older firmware version.
