THEbarbarian87's avatar
Aug 05, 2021
ABSOLUTE TRASH mr80 and the app
To the day when the armor trial expired. Poof my settings changed. Internet would crash every 24 hours. Factory reset is failing completely. This is the biggest piece of **bleep** mr80 and 2 ms80s
1 Reply
  • plemans's avatar
    Why is factory reset failing?
    What error is it giving you?
    Are you using the reset button? You push and hold it for 7-15 seconds while the device is powered on?
    Or are you going through the gui menu for reset?
