dennisalanfenst's avatar
Sep 05, 2020
AC1750 model 6250
I have been at this setup for hours countless hours right about now a 10lbs sledge hammer is going to fix it. I go from one frustration to another what’s worse WiFi shortages or a extender that is screwed.
I even took a picture of extender admin login username & password & they don’t work either, the NIGHTHAWK APP is useless all it does is loop loop I have to keep deleting app & restarting.
The Motorola AC1700 router doesn’t not have WPS button. & the IP address is not the same as the Extender.
iPhone XS Max....
Do this do that do this do that try this try that. I AM SO F Pissed.
ooooooh it’s so simple you just!!! BS
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello,
    May you provide us with the model number of the devices you're referring to? (ex. R7000, EX8000)
    Thanks,
    Christian
