Retired_Member
Aug 16, 2021Accidently updated the router before satellite on MK63
According to this web page: https://kb.netgear.com/000063806/MR60-MS60-Firmware-Version-V1-0-6-112-Hot-Fix I'm suppose to update MS (satellite) first then MR (router) second. As the title...
- Retired_MemberAug 24, 2021
It looks so simple when it works, wow! I'll have to start using FF from here on.
Aug 16, 2021Guru - Experienced User
You need to update the RBS before updating the RBR. Keep this in mind for future updates.
See if this process works for the MK series as it works for Orbi systems:
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
Retired_Member
Aug 16, 2021Thanks FURRYe38 for reply,
Will try this option and will report back.
