Retired_Member
Aug 16, 2021Accidently updated the router before satellite on MK63
According to this web page: https://kb.netgear.com/000063806/MR60-MS60-Firmware-Version-V1-0-6-112-Hot-Fix I'm suppose to update MS (satellite) first then MR (router) second. As the title...
- Retired_MemberAug 24, 2021
It looks so simple when it works, wow! I'll have to start using FF from here on.
Aug 16, 2021Guru - Experienced User
You need to update the RBS before updating the RBR. Keep this in mind for future updates.
See if this process works for the MK series as it works for Orbi systems:
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
Retired_Member
Aug 17, 2021After factory reset the RBS and log in as admin and password (default) and the update is completed.
Do i need to change password on RBS from default to match RBR prior syncing?
- FURRYe38Aug 17, 2021Guru - Experienced User
Good to hear. No, just re-sync the RBS to the RBR and it should acquire the data it needs.
- Retired_MemberAug 21, 2021
@FURRYe38,
The RBS #1 is seems to be straightforward as your procedure. But when try to working on RBS #2, after factory reset I could not log in as 192.168.1.250 not sure why.
As for RBS #1 I was able to re-sync both wifi backhaul and wire backhaul. After log in to router, i can see RBS #1 is firmware V1.0.6.112.
For RBS #2 is still working/syncing on both wifi backhaul and wire backhaul and it shows V1.0.6.102 firmware.
I have tried updating RBS #2 thourgh routerlogin.net using V1.0.6.116 (8/18/2021), but still failed.
For now i have both RBS1 and 2 and RBR working as follow:
RBR = V1.0.6.112
RBS1 = V1.0.6.112
RBS2 = V1.0.6.102
Any ideas?
Thanks,
- FURRYe38Aug 23, 2021Guru - Experienced User
So with the RBS#2 ethernet connected to the RBR, it appears as connected and can you access it's web page at the assigned IP address using a web browser and send the FW file to it using MS Edge or Firefox?
