Retired_Member
Aug 16, 2021Accidently updated the router before satellite on MK63
According to this web page: https://kb.netgear.com/000063806/MR60-MS60-Firmware-Version-V1-0-6-112-Hot-Fix I'm suppose to update MS (satellite) first then MR (router) second. As the title...
- Retired_MemberAug 24, 2021
It looks so simple when it works, wow! I'll have to start using FF from here on.
Retired_Member
Aug 17, 2021After factory reset the RBS and log in as admin and password (default) and the update is completed.
Do i need to change password on RBS from default to match RBR prior syncing?
Aug 17, 2021Guru - Experienced User
Good to hear. No, just re-sync the RBS to the RBR and it should acquire the data it needs.
- Retired_MemberAug 21, 2021
@FURRYe38,
The RBS #1 is seems to be straightforward as your procedure. But when try to working on RBS #2, after factory reset I could not log in as 192.168.1.250 not sure why.
As for RBS #1 I was able to re-sync both wifi backhaul and wire backhaul. After log in to router, i can see RBS #1 is firmware V1.0.6.112.
For RBS #2 is still working/syncing on both wifi backhaul and wire backhaul and it shows V1.0.6.102 firmware.
I have tried updating RBS #2 thourgh routerlogin.net using V1.0.6.116 (8/18/2021), but still failed.
For now i have both RBS1 and 2 and RBR working as follow:
RBR = V1.0.6.112
RBS1 = V1.0.6.112
RBS2 = V1.0.6.102
Any ideas?
Thanks,
- FURRYe38Aug 23, 2021Guru - Experienced User
So with the RBS#2 ethernet connected to the RBR, it appears as connected and can you access it's web page at the assigned IP address using a web browser and send the FW file to it using MS Edge or Firefox?
- Retired_MemberAug 23, 2021
Yes, with RBS#2 ethernet connected to the RBR i can access its web page. That's where i can see (RBR = V1.0.6.112, RBS1 = V1.0.6.112 and RBS2 = V1.0.6.102)
But when i try to send RS FW file either V1.0.6.112 or latest 116 still fail using google chrome.
