Retired_Member
Aug 16, 2021Accidently updated the router before satellite on MK63
According to this web page: https://kb.netgear.com/000063806/MR60-MS60-Firmware-Version-V1-0-6-112-Hot-Fix I'm suppose to update MS (satellite) first then MR (router) second. As the title...
- Retired_MemberAug 24, 2021
It looks so simple when it works, wow! I'll have to start using FF from here on.
Aug 24, 2021Guru - Experienced User
Great news and glad you got it working.
Ya, FF is my go to for FW processing. Other browsers like Chrome and others seem to not process the operation fully or correct sometimes. FF always seems too work best, at least for me.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Retired_Member
Aug 24, 2021It looks so simple when it works, wow! I'll have to start using FF from here on.
- FURRYe38Aug 24, 2021Guru - Experienced User
:smileywink:
