emachuca
Dec 28, 2024Aspirant
Add a Night hawk mesh system to my existing Nighthawk router
I have an existing Nighthawk XR1000V2. I just purchased a Nighthawk AX3000 Mesh system. I would like to continue using the XR1000 as the router and have all of the kit (including the MR70 Router/Sate...
- Dec 28, 2024
Disable the XR1000s radios and configure the MR for AP mode:
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
emachuca
Dec 29, 2024Aspirant
Thank you sir!
Dec 29, 2024Guru - Experienced User
Enjoy. 📡
