Hutcherml
Sep 11, 2022Follower
Add satellite MR60 to MS80
Are there conflicts to mixing the MR60 (satellite) with the MS80 network?
Sep 11, 2022Guru - Experienced User
You can use MS60 satellites with the MS80 satellites but you can't use the MR60.
The following configurations are supported with the MK83:
- MR80 + MS80
- MR80 + MS60
- MR80 + MS80 + MS60
