Jcbear
Feb 29, 2024Aspirant
Add satellite
I have the nighthawk mesh 6 MR70 my router is connected to modem and desk pc have 2 satellites 1 upstairs master bedroom and 1 in family rm looking to add 1 more in lower level will it work or do I ha...
- Mar 01, 2024
Outter fringes of distances but ya, might try another MS of same model series.
Feb 29, 2024Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡 ‌‌🛰️
Jcbear
Upstairs approx 50’ from router family rm 40’ from router new satellite would be in basement approx 60-70’ from router 1st&2nd level is drywall and wood studs lower level is drywall wood and metal in ceiling current satellites are wireless as would the additional satellite
- FURRYe38Mar 01, 2024Guru - Experienced User
