MTUser2013
Jan 28, 2021Tutor
Adding Satellite to a Costco NightHawk Mesh System
I am not sure I selected the right model. But, it is the mesh system that came from my purchase at Costco. I purchased another satellite that I want to add to this system. I bought mine used on eBay....
Jan 28, 2021Guru - Experienced User
What model mesh system do you have?
What satellite model are you trying to connect?
- MTUser2013Jan 28, 2021Tutor
plemans wrote:What model mesh system do you have? The router says MR60 on the bottom
What satellite model are you trying to connect? The new satellite says MS60 on the bottom.
- plemansJan 28, 2021Guru - Experienced User
here's the install guide for the mk system
How do I install my NETGEAR Mesh WiFi 6 System? | Answer | NETGEAR Support
plemans wrote:here's the install guide for the mk system
I've tried this several times. The satellite is within 3 feet of the router. The light stays orange. I see a pin hole and the label reset. Can that help solve this problem?
