MTUser2013
Jan 28, 2021Tutor
Adding Satellite to a Costco NightHawk Mesh System
I am not sure I selected the right model. But, it is the mesh system that came from my purchase at Costco. I purchased another satellite that I want to add to this system. I bought mine used on eBay....
Jan 29, 2021Guru - Experienced User
Maybe amber?
is it solid/pulsing?
Is it just the satellite with the issue?
Do you know what firmware is on the router and what one is on the satellite?
if the satellite doesn't connect to the router, you should be able to hardwire a pc/laptop into the ethernet port on the satellite. Then use 192.168.1.250 to connect to it (default address if not connected). that'd let you check firmware/upgrade it if needed.
you can find manuals, firmeware here:
MTUser2013
Jan 29, 2021Tutor
Please below for the inline answers
plemans wrote:Maybe amber? Yes
is it solid/pulsing? Solid
Is it just the satellite with the issue? Yes, the new one I am try to add.
Do you know what firmware is on the router and what one is on the satellite? No. How would I find out? Disconnect it and plug in a cable and do below like for the satellite?
https://www.netgear.com/support/product/mk62.aspx
OK. I will check on the firmware and see if it needs upgraded. I note you
- plemansJan 29, 2021Guru - Experienced User
let me know how it goes!
Never played with the nighthawk mesh system but it should be fairly similar to orbi
