cjoe69
Aug 15, 2025Aspirant
Additional security required?
I just purchased the Mesh system with 2 satellites. It took me about a half hour to set up, because it kept taking me in a stupid set up connection circle. Finally got it going. TV's connect, phones ...
cjoe69
The whole thing seemed fishy. It's the AX3000 system. I had never heard of the "router software for updates". I clicked support under the app and there was a number, so I dialed that. 844-429-1763. When I just googled it, Netgear comes up right away. The first fishy clue was that someone answered immediately, no recording to press 1, etc. I had my son stop by and he messaged his IT guy and we reset everything and restarted and it finally connected. When I clicked support again (in the app) to look at the number, a different "page" came up, which showed chat support and phone support. That was definitely not there the first time I clicked it, so I don't know what or how that would have gotten switched. Glad I went with my gut and just hung up. Thanks!
Aug 15, 2025Guru - Experienced User
Where did you get the initial phone number at? Where was this indicated?
Only authentic NG Support number is located here: https://my.netgear.com/support/contact.aspx
