iamgeorge
Oct 22, 2020Guide
Amber ligth on MS60
Hi, When i sync between my MR60(router) and MS60(satellite) of my MK62, If both of them are placed near, then both of them will show blue light. But when i keep my satellite in a differenct area ...
Christian_R
Oct 27, 2020NETGEAR Employee Retired
Hello,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Priceawolowitz
Oct 29, 2020Initiate
NetGear products made recently have been horrible and are no longer at the same level as they used to be. On top of that paying for the additional NetGear support has been completely useless and support never has the answers. All the new WiFi6 mesh products have the same underlying problem where the satellites fail to communicate with the router and the connection fails. This problem is known to NetGear in both the Nighthawk and Orbi products but they do not have an answer and con you into buying their extended “worthless” support.
