iamgeorge
Oct 22, 2020Guide
Amber ligth on MS60
Hi, When i sync between my MR60(router) and MS60(satellite) of my MK62, If both of them are placed near, then both of them will show blue light. But when i keep my satellite in a differenct area ...
JoseEC
Jan 10, 2021Initiate
I have the MK62 Product (MR60 and MS60).
I was able to solve this by unplugging and replugging the MS60 satellite into the power outlet, then inserting a pin into the hole on the back of the satellite to do a Hard Reset.
The satellite came on with a blinking white LED, then it changed to amber for 1 minute, then it went to blue.
Can you try this and see if it solves your issue?
