EternalStudent
Feb 13, 2023Apprentice
Any easy way to see current speeds being used?
I have the mk63 mesh set, and know it has a "traffic monitor" feature to measure total bits sent per time period and stop after a set point has been reached. I've been grateful while using Xfinity's...
michaelkenward
Feb 13, 2023Guru - Experienced User
EternalStudent wrote:
But I don't see a way to use that area or anything else to see momentary aka live speeds. Meaning how much usage is happening on my whole network, though WAN plug speeds are the worry.
I'm not sure that I follow your message, but if you are asking if there is a way to see the bandwidth for each user then Netgear routers do not support this.
