cpthk
Dec 14, 2023Aspirant
Anyway to tell which band and channel the satellite backhaul is using?
My devices that connect to the satellites are having slow internet. Speed test showing only ~ 5mbps. I am suspecting the problem is the backhaul connection from satellites to the main router. Is ther...
cpthk
Do you mean it uses the same channel as all other client devices? Does it not have a dedicated channel only for router to satellite?
schumaku
Dec 15, 2023Guru - Experienced User
Any other routers, gateways, or even wireless speakers or video systems operating (and in use) in the same area?
