Jim100
Jan 25, 2022Tutor
App speed check does not display speeds
mesh 6 router with two satellites MR 63 . Net gear app on my iPhone and iPad. Speed check runs but does not display speeds, only says I have moderate speed.
- Feb 03, 2022
All of a sudden it has now working just fine. I have no idea why.
Jan 25, 2022Guru - Experienced User
when you run it off a device and not off the netgear app, does it work?
its a more trustworthy test anyway
Jim100
Jan 25, 2022Tutor
Other speed checks work, I've tried removing the app and putting it back in on both iPad and iPhone. Rebooting modem and router. All firmware is up to date so I'll told. All other functions on the app work.
- plemansJan 25, 2022Guru - Experienced User
what modem/gateway is the MK system connected to
- Jim100Jan 25, 2022Tutor
My modem was supplied by spectrum/charter is a Hitron E31N2V1. Should I replace it with my own modem?
No. I was just making sure you weren't in a double nat. It can cause issues. You're not.
Does the speedtest work if you go through the router's browser?
