mikey59
Aug 21, 2023Guide
Apple devices cannot conect!
Stating yesterday, I have been having problems with iPhone, iPad, Macbook, connecting to Wi-Fi It shows as available, but when connecting, it goes from connected to not 2 or 3 time & then just shows...
- Aug 22, 2023
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
It shows as available, but when connecting, it goes from connected to not 2 or 3 time & then just shows in my list of networks.
I have reset network settings & restarted phone numerous times, forgotten & rejoined numerous time,
Looking for suggestions!
michaelkenward
Aug 21, 2023Guru - Experienced User
Does this ring any bells?
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
and
Use private Wi-Fi addresses on iPhone, iPad, iPod touch and Apple Watch – Apple Support (UK)
- mikey59Aug 21, 2023Guide
Turned off private Wi-Fi address & now it keeps telling me the &$^%##*& password is wrong!!!
This had been working fine since the beginning of the year - what would have suddenly changed to &%#$ that up?
- FURRYe38Aug 22, 2023Guru - Experienced User
Forget the connection on the apple device then re-connect with the WiFI Private IP address disabled.
- mikey59Aug 22, 2023GuideAnd now it’s back to telling me wrong password!
Dunno if this is related or not, but now my windows laptop is just giving me the generic ‘cannot connect to this network’ message…
