mikey59's avatar
mikey59
Guide
Aug 21, 2023
Apple devices cannot conect!
Stating yesterday, I have been having problems with iPhone, iPad, Macbook, connecting to Wi-Fi It shows as available, but when connecting, it goes from connected to not 2 or 3 time & then just shows...
  • FURRYe38's avatar
    Aug 22, 2023
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
    Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
    I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
    It shows as available, but when connecting, it goes from connected to not 2 or 3 time & then just shows in my list of networks.
    I have reset network settings & restarted phone numerous times, forgotten & rejoined numerous time,
    Looking for suggestions!
