mikey59
Aug 21, 2023Guide
Apple devices cannot conect!
Stating yesterday, I have been having problems with iPhone, iPad, Macbook, connecting to Wi-Fi It shows as available, but when connecting, it goes from connected to not 2 or 3 time & then just shows...
- Aug 22, 2023
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
It shows as available, but when connecting, it goes from connected to not 2 or 3 time & then just shows in my list of networks.
I have reset network settings & restarted phone numerous times, forgotten & rejoined numerous time,
Looking for suggestions!
mikey59
Aug 22, 2023Guide
Keep in mind, I've had a couple of Samsung TVs connected with no issues (so far)...
Firmware - V1.0.3.34_2.0.58
Modem is my own Arris Surfboard SB6190
Cable is the one that came with the Netgear package
Restating everything appears to have fixed it, but keep in mind I did do all that Sunday night when the first Apple product (the wife's Macbook Pro) started having issues.
Aug 22, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
